Lahegas bildetråd og div tips/triks - konstruktiv kritikk
24mm på ett crop kamera er litt lite vidvinkel for min smak. Ville byttet det ut med ef-s 17-55 f2.8 is. Hvis du trenger 300mm så virker det som 70-300 is usm (den "billige" utgaven) er ett bedre kjøp enn DO utgaven:
http://www.photozone.de/canon-eos/201-canon-ef-70-300mm-f45-56-usm-is-lab-test-report--review
"In principal the Canon EF 70-300mm f/4.5-5.6 USM DO IS is a very interesting lens ... in principal. From a performance point of view it delivers all that a consumer has hoped for - high resolution figures in conjunction with low distortions, low vignetting and low chromatic aberrations and all packaged in a quite sturdy, small package with high speed AF. So what is the problem ? Well, it's the price tag. The optical performance of the new EF 70-300mm f/4-5.6 USM IS (non-DO) is simply about as good. Mechanically it isn't quite in the same league as the DO lens but ... hey - it comes at a 50% lower price tag! If we throw in the added values plus a little coolness factor the DO lens may be worth a 200-250 EUR/$ premium over the conventional lens but at 1100 EUR/US$ it is simply way over-priced (also true for the EF 400mm f/4 USM DO IS). So unless Canon reduces the price to something more in line with the (in-house) competition there're some question marks whether the lens is really worth the extra financial sacrifice."
Test av "billig" utgaven:
http://www.photozone.de/canon-eos/200-canon-ef-70-300mm-f4-56-usm-is-test-report--review
Hvis du kan klare deg uten 300mm så er det ingenting som slår 70-200 F4 IS USM:
http://www.photozone.de/canon-eos/196-canon-ef-70-200mm-f4-usm-l-is-test-report--review
"Every now and then EOS, the goddess of mercy, seems to speak to the Canon lens designers and this time they listened carefully. The Canon EF 70-200mm f/4 USM L IS may well be the very best tele zoom on the market today"
Støtter det fult ut.
Det var akkurat en slik tilbakemelding jeg var på jakt etter. Jeg har faktisk sittet å vurdert 17-55 linsa i stedet for 24-105. Du får et mer lyssterkt objektiv samt at det gir mer vidvinkel.
Tele linsene er vel den jeg er mest usikker på. Ser du anbefaler 70-200 F4 IS USM, men det er klart at jeg kommer til å tenke nøye igjennom før jeg kjøper noe. Det er jo alternativer som er "nærme" dine anbefalinger her, slik som:
* Canon EF 70-200 f/2.8L USM
* Canon EF 70-200 f/2.8L IS USM
* Canon EF 100-400mm f/4,5-5,6L IS USM
Mvh
Maarten
Mvh
Maarten
Brukte stort sett bare 17-55 f2.8 is når jeg hadde canon, og var veldig fornøyd med den. Minus er en noe billig konstruksjon så det samler seg fort støv inne i objektivet og det finnes ikke vært tett på noen måte. Men for landskap og eventuelle bilder på messer, eller innedørs på fester/bursdager o.l så blir 24mm fort litt begrensende. Du har jo 17-40 f4 også, men for meg som ikke er så stødig på hånda så er IS nødvendig..
Du kan ta en titt her:
http://www.the-digital-picture.com/Reviews/Canon-Zoom-Lens-Reviews.aspx
Omtaler av canon objektiver. Sjekk "ISO 12233 CROPS" inne i omtalene. Der kan du velge 2 objektiver og sammenligne skarphet mot hverandre på forskjellige brennvidder og blendere. Prøv f.eks 100-400 på 400mm f5 mot 70-200 f4 is usm på 200mm f4 og se forskjellen ;) Men selvfølgelig så er det som må telle mest med zoom objektivet er hvor stor brennvidde du trenger. For fugle fotografi så blir nok 200mm litt kort..
