Når jeg(man?) trykker på en artikkel eller guide får jeg(man?) ikke bare error, men fatal error :(
Det skjer her også :(
Fatal error: Call to undefined method ipSeoMeta::user_popup() in /home/detaiprv/public_html/forum/admin_detailers/applications_addon/ips/ccs/sources/pages.php(419) : eval()'d code on line 1729
Klar over den. og står øverst på siden at det ikke fungerer ;)
Feilsøker det nå :)
Hmmm designet var jo fint nok det, men er det like mye trøbbel på PC som med iPhone 4? Mye rart her (er på ferie så jeg kan bare bruke den).
Har ikke testet iPhone men har prøvd med noen andre mobiler og ser bra ut der. hva er det som ser rart ut?
Helt øverst på skjermen kommer dette på min android:
Warning: explode() expects parameter 2 to be string, array given in /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/publicOutput.phpon line 1133
Warning: Invalid argument supplied for foreach() in /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/publicOutput.php on line 1135
Warning: Cannot modify header information - headers already sent by (output started at /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/publicOutput.php:1133) in /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/formats/html/htmlOutput.php on line 116
Warning: Cannot modify header information - headers already sent by (output started at /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/publicOutput.php:1133) in /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/formats/html/htmlOutput.php on line 127
Warning: Cannot modify header information - headers already sent by (output started at /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/publicOutput.php:1133) in /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/formats/html/htmlOutput.php on line 136
Warning: Cannot modify header information - headers already sent by (output started at /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/publicOutput.php:1133) in /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/formats/html/htmlOutput.php on line 137
Warning: Cannot modify header information - headers already sent by (output started at /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/publicOutput.php:1133) in /home/detaiprv/public_html/forum/admin_detailers/sources/classes/output/formats/html/htmlOutput.php on line 141
Helt nederst kommer header logoen flere ganger etter hverandre nedover.
Har selv vært borti å oppgradere forum som driver hjemmesider, og det er en drøy, men viktig jobb!
Endret av bjovas
Dere som bruker anroid, bruker dere den appen? hvis ja se at dere bruker siste versjon av den
Hvilken app tenker du da på, tapatalk?
I dette tilfellet bruker jeg standard nettleser, men kan godt teste med en app om du sier hvilken du mener. :)
Edit:
Problemet kom ikke når jeg testet med firefox på android, akkurat nå.
Endret av bjovas
Jeg kommer heller ikke inn på innleggene med min Iphone 3gs. Får opp forumsiden, men kommer ikke inn..
IP.board har en app til iPhone og Android.
Prøver du mobilskin eller standard? kan du prøve å slette temp og cookies?
Tror jeg bruker standard skin.
Har prøvd å slette temp og cookies, det hjalp ikke.
Nå kom jeg på den appen du snakket om! *teste*
Ingen problemer ved bruk av appen så vidt jeg kan se. :)
Oi...wtf? Nå skjønte jeg lite her....her var det forandra ja...*dislike* :(
kalevipalo
Har problemer med nettsiden når jeg surfer med Iphone 4, men når jeg bruker datamaskina så vises sidene normalt. Er det lenge til dette blir fikset?
Er det bare jeg som ikke får opp stort bilde når jeg trykker på bildene slik det var før?
Har prøvd med flere mobiler her, men har ikke noe tilgang på iphone . Så får ikke testet den, men virker rart at iphone skulle slite når det vises fint på andre mobiler og nettlesere for pc-er.
Har du mulighet til å beskrive hva som ser feil ut og eventuelt et bilde av hvordan det ser ut?
Ser ut til å fungerer fint slikt som før her. hvordan nettleser bruker du?
Ser det har kommet opp noe jeg har savnet før,og det er at det står når tråden ble startet. Pluss for den.
Gjort noen justeringer av farger og en del andre ting, så skal se bedre ut nå :) kom gjerne med forslag til forbedringer.
Syntes teksten er veldig uksarp, mot bakgrun. tror det hadde gjort seg med en annen font/farge.
mye "fancy" skygger og greier her som gjør det hele mindre oversiktilg en det var.
også syntes jeg bare disse "bitte" små avatarene som er ved siden av "trådtittel" og eller bruker er irriterende. ingen som ser bildene alikevel siden de er så små.
Men bortsett fra dette, som sikkert er små justeringer. ser det bra ut.. greit å fornye seg en gang i blandt :)
Endret av Tyggern
Mvh Torgeir Thorud
Hmm, i dag var plutselig feilmeldingene jeg nevnte i går dukket opp når jeg brukte android ipb appen.
Skal ikke være bastant på at ting ikke funker med denne browseren, jobbmaskina kjører IE 7.0... Google+ kalte den utdatert... Prøver meg litt frem med iPad i løpet av dagen, gir beskjed om det skulle dukket opp noe der.
En liten ting først - jeg savner en funksjon. Tidligere kom jeg rett til siste uleste innlegg i emnet når jeg klikket på emnet i forumet - er det ikke slik lenger? Evt. er det en setting man må huke av på? Likte det svært godt, irriterende å måtte klikke på "Go to first unread post". (Evt. kan det være at funksjonen opptrer noe ustabilt, virker som om det ikke skjer i alle emnene.)
Mens jeg skriver dette, merker jeg at tastatur-kombinasjonen ctrl + delete (for å slette hele ord) ikke fugerer. Det gjør derimot omvendt løsning med ctrl + backspace. Litt nerdete kanskje, men hurtigtaster gjør dagen min ;-)
I tillegg ser det ut til at det skjer litt mye html-koding når jeg klikker "Forhåndsvis innlegg" før jeg svarer. Kan ikke huske at forrige forum-versjon satte inn en paragraph ved avsnittene? Og av en eller annen grunn blir avsnitt laget med "Enter" gjort om slik at de to setningene som skulle vært siste i ett avsnitt og første i neste, derimot blir stående rett etterhverandre uten mellomrom.
Har i hvert fall endt opp med å skrive dette i Notepad med egen koding, det blir litt mye koder innblandet i teksten.
Ellers tenkte jeg å si at jeg liker designen godt. Rent og pent, og - også noe raskere?
996 C4 | A6 avant 2.4 q tip
Får dere enda feil med mobilene nå? har endret på noe nå.
Det er sjelden jeg misliker forumoppdateringer, men dette syns jeg var et skritt i feil retning, sammelignet med layouten det var før. :)
