T.Bakker
Rain-X
37 innlegg i emnet
Hvordan legger man Rain-X på best mulig måte ?
Skrev en lengre avhandling på Detailing World, så jeg siterer den like godt her :)
After several partially successful and failed attempts over the last couple years I've come up with this method that finally worked perfectly:
Using a lint free paper towel, folded 2-3 times (about the size of four fingers), apply 5 drops or so to "prime" it and rub it on in small, overlapping circles. Feel free to vary with some straight lines around the edges, though. Once you can no longer see the stuff being smeared on or it seems to evaporate within a second, add a couple more drops to the paper towel and continue. I'm probably using 4-6 drops per quarter section of the windscreen after the initial prime. Allow to dry for 15 minutes and buff off thoroughly with a clean, dry MF. If you don't see much hazing at this point, don't worry. In my experience there's only proper hazing after 2nd or 3rd layer.
Wait an hour or so and repeat to add a second layer, hopefully covering the areas you've missed or Rain-X hasn't bonded properly. Then find some rain default_smile.png
If you then get areas where the beading is different than others (I usually do) or you get smearing when using wipers, try adding a quick 3rd layer, paying extra attention to the areas in question.
This may seem like a lot, and according to the instructions it is, but then again I've often heard people having to add layer after layer until the Rain-X itself beads to get the desired results default_smile.png
Jeg bruker en slik:
http://www.swissvax.no/produkter/microfiber-og-handklaer/art-378-swissvax-cleaner-fluid-paforingspute
Som jeg sprayer RainX på (har helt den over i en liten sprayflaske) og deretter drar kjapt horisontale drag over ruten, så vertikale for å sikre full dekning. Lar dette så ligge på fra 20min-flere timer.
Jo lengre RainX ligger, jo værre er den å buffe (i motsetning til Nanolotus som jeg ikke får dette problemet med).
Buffer da med en våt mikrofiber for å få ruten helt strøken.
Jeg bruker en slik:
jeg dreit meg litt ut på dette. Var ikke helt klar i tankene, så jeg sprayet på med RainX på speilet på badet og tok nalen for å ta det av. Ikke så mye effekt da gitt.
Men smart tips. Prøve å ta på med påføringspute var ikke dumt!
Jeg har følgende fremgangsmetode:
- Tar på meg ett par hansker
- Finner frem RainX og en pakke med sminkepads (får kjøpt omtrent overalt)
- Tar ut noen pads og heller på 1-2 cl med produkt
- Legger i vertikale og horisontale, rette linjer, som gjerne overlapper hverandre for å fylle hele ruten
- Lar det ligge i ca 30 min
- Buffer av med fuktig mf-klut
Chris: Ser du stor forskjell på holdbarhet om den ligger i 30 min eller 10 minutter? Bare lurer :) Jeg har ikke testet å la den ligge på lenge på min bil enda, men vurderer det sterkt for å få en bedre holdbarhet :)
Rain-X spiser opp disse "standard" små gule påføringsputene.
Er vel no-name, Turtlewas, megiars osv bl.a. som har disse.
Alkoholen gjør vel at skumgummien går i oppløsning ja. :)
Jeg har prøvd med skumgummipad, men syns ikke det ble jevnt nok. Derfor gikk jeg tilbake til en slik MF pute som den jeg linket til.
Legger den i en ziplock-pose fra gang til gang, så den kan lett brukes et år i slengen.
Jeg har ikke opplevd noe forskjell, da jeg ikke har latt det ligge mer/mindre enn 30min. Alltid gjort det slik pga det var slik med Aquapel, og det funket veldig bra :)
Loer ikke de sminkepadsene inni hampen da?
Overhodet ikke.
Jeg også bruker sånne små søte sminkepads i bomull (no homo) etter tips fra dette eminente forumet , og de loer ikke hos meg iallefall.
Rette linjer er forøvrig min favorittmåte å legge på også, og i to til tre lag! :)
Overhodet ikke.
Sweet, får prøve :)
Takker for alle tips/svar.
Da hadde vel alle kvinnfolk gått rundt og sett ut som pudler?
:rofl1::rofl1:
Var den dag jeg hadde dårlig tid og la turtle sin type rain-x, altså rain-off eller noe slikt. Den ble lagt på samme måte som rain-x, men når den skulle buffes av, skulle man spraye vann på ruta først og så tørke av vannet med microfiber, og dette funket KNALL! Fikk opp et lys for meg, noe som vet om dette funker på rain-x også? Blir vell kanskje det samme som å bruke en våt microfiber, eller? :)
ja, det blir det samme. Som nevnt over så er Rain-X et helvete å få av når den har ligget på en stund, så da tar man en våt mikrofiberklut som man tar av med. ^_^
Fikk en aha-opplevelse når jeg fant ut at jeg ikke trengte å stå å gnikke og gnure (polere det vekk)! :D
Hvordan funker det å legge Rain-X når det er såpass kaldt som det er nå da? Fikk en flaske i posten i dag, å er ivrig etter å prøve, men er også litt skeptisk når temperaturen kryper ned under 10 minus..
Dra til en innendørs vaskehall og gjør det, det gjør jeg, funkerer bra :)
