Mercedes CLS 320 - Evolution Detailed
Evo-Detailing
Honestly, I did not expect such a good feedback from you guys at the Toyota post. So as a consequence of that, here is a work I did a while ago.
I have spent 3 days working on this car, more than 25 working hours that is.
The initial state was something like this :
Closer. you can see more defects :
2Bm - CG Maxi SudsII, wash mitt Sonus
APC - CG GreenClean
Sonus Green - clay
ONR, as lube.
After the wash - results -
Curious, fingerprints in the clearcoat... wierd...
Being cleaner now, the paint showed little more defects, this being the way the paint looked over the entyre car.
Of course there were areas which showed more severe defects, like these :
Test area - the trunk lid, 3M FCP + Orange LC pad were the weapons of choice
Corrected :
Flashlight (no IPA or LSP)
The roof :
B4
After compounding :
Larger view :
50/50
Macro activated :
Abstraaact :)
Reflection with no finish :
50/50
Result :
Swirls
buffer trails :
Remember her ?
All gone now
Untouched door vs corrected fender
More photos
Mirroring Honda
Finish 106FA on black Mirka pad.
CG XXX, left to cure about one hour
Alex Lascu
EVOLUTION DETAILING
  • DCN Poeng 32
Good work there, the paint really needed some treatment!
About the finger prints, my girlfriends black Golf had exactly the same looking fingerprints on the back right door. I tried various of degreaser's and even clay, but nothing removed them. Scholl S03 Gold compound did the trick though. It really seemed like the fingerprints had etched to the paintwork. Someone with bad PH value on their hands must have touched the paint i suppose :P
Endret av Bilpleie gærning
Really nice work, sunblock made similar fingerprints marks on a car that i took.
Green button pushed :thumbup:
Yet another great detail from you. Good write up too! :)
+1 cred
Great work again..
Black is back :)
Cred given
Great work, I did a car with the same colour during the winter and the clearcoat was very hard to correct on that one, what about the one you did?
Say hello to the lady in some of the reflection pics from me :)
Evo-Detailing
1'rst of all I want to thank you for the appreciation of my work.
The fingerprints, have an explanation. Somebody touched the panel while the paint was still fresh, as that door had been resprayed.
I only could remove them by WS and then polish.
@Bernhard - Hello back to you (from the reflection), and yes, being a Merc, and quite a new one it has that ceramic clearcoat which is very hard to correct, but once done... "Shine Happens" :)
Thank you.
I figured so, how many hours did you use? The one i did was very banged up, so I used around 30 hours just on the paint, I did 6-8 hits with Scholl S3Gold and yellow Scholl cutting pad on each panel.
But your result looks superb, so keep up the good work and keep 'em coming :)
Great work and good writeup :)
Looking forward to the next S&S from you.
Cred given.
Daglig leder
Automotive Detailing AS
Håndverksvegen 15
3917 Porsgrunn
Good work! I've also seen fingerprints in the clear coat, but that was from (believe it or not) someone with urine on their fingers having hold onto the door for a few minutes (a very drunk idiot). People with hands full of sunscreen lotion also leave nasty marks in the clear coat....
Evo-Detailing
About sunscreen lotion I haven't heard yet, I knew about urine, and it is true, you wouldn't belove how corrosive that stuff is.
Thank you very much for the good words, most appreciated.
@Bernhard - the time it took, as I said in the first post, it was somewhere over 25 hours. Since I don't have Scholl products yet, I used Menz S100 on a white LC pad, and in places the S100 was replaced by F500 (which, in my opinion is quite the same, the only difference being that F500 does not produce so much dust, and because of that you cand work it for long. Longer passes mean better correction in that case. The FCP that I tryed on the trunk left me with too deep marks, and those were quite difficult to remove).
About sunscreen lotion I haven't heard yet, I knew about urine, and it is true, you wouldn't belive how corrosive that stuff is.
  • 1 year later...
Nice work! Actually looking to buy one of these soon!
You're a lucky one :)
Good work and the first englishtexted S&S i have read at the forum :)
