Oppdatering av forum i kveld
Har planlagt å oppdatere forumet i natt fra 4.0 til 4.1. Regner med en nedetid på ca 1-2 timer fra kl 23 i natt.
Teksteditor får seg en liten overhaling samt at det skal bli lettere å finne fram til egne innlegg og følge med på nye innlegg med støtte for "push" varsler også rett i nettlesere som støtter det. Menyen blir også endret litt på.
Ellers blir det meste likt som idag. Håper at denne oppdateringen løser de resterende punktene som ikke alle har vært fornøyd med :)
Changes and New Features Include:
  • New menu structure and drag-and-drop menu manager
    • Ability to have two menu levels
    • Option to create both custom-link menu items and embed preconfigured menus
    • Preview before publishing
    • All menu items support group permissions
  • Discovery system that allows for both admin and user created Activity Streams
    • Admin-defined streams always visible to users. Users can edit and save admin streams to create their own, custom copy.
    • The main show-all stream automatically tells you when there is new activity
    • Users can create custom streams
    • User streams can be shared but viewer will only see content based on their permissions
    • Filter options include:
      • All content or specific apps. Some apps support further refinement into categories or content-type.
      • Unread content
      • Ownership
        • Content I posted in
        • Content I started
        • Content by specific members (user can create a list)
      • Content I follow
        • Areas I follow
        • Specific content I follow
        • Posted by members I follow
      •  Time Period
        • Any time
        • Since my last visit
        • Specified number of days
        • Specific date range
    • Activity Streams that reference features not available to Guests such as unread tracking and follow system will auto-hide
  • Option to serve images via a local proxy script (useful for SSL sites)
  • Option to globally disallow remote images in posts
  • Ability to preview email template wrapper
  • Version number in AdminCP header
  • Selective quoting to highlight a bit of a post and quote just that
  • Pages application enhancements
    • Now installs with better default content to help new users
    • Pages menu manager removed in favor of Suite-wide menu manager. Upgrade system will attempt to preserve menu items.
    • Blocks
      • New blocks
      • Members block, Blog comments, Blog List, Download comments, Download reviews, Poll block
      • commentFeed/itemFeed based widgets have date limit (today, 7 days, etc)
      • RecordFeed has a customisable title
      • Calendar widget has a calendar selector to restrict events to specific calendar(s)
      • Better selectors for open/pinned/featured selection
      • External Widgets: Ability to add blocks to other websites via generated iFrame code
    • Pages
      • Larger editor box when editing/creating pages
      • More tags in sidebar when editing/creating pages
      • Custom error page configurable
    • Fields
      • Simple relational field added
      • Ability to place fields above or below record content
      • Simple Name: Value display format added
    • Media Manager
      • Ability to upload media for use within Pages pages, CSS, templates and blocks
      • Compatible with designers mode
    • Templates
      • New templates for when viewing the record homepage as 'articles'
      • Ability to export and import templates to share with other IPS4 communities
  • Gallery application enhancements
    • New upload image process
    • Images and movies are submitted to the same upload field
    • Image reviews
  • Editor updates
    • Uses div-mode which is much faster and more reliable. Clicking into the editor is now pretty much instant.
    • Auto-linking and member mentions to use new APIs for better reliability
    • Quotes, code boxes, and spoilers can be dragged and moved and there is no more "red line"
    • When cmd/ctrl right-clicking: options to remove or break-out of quotes, edit links and edit image properties
    • Pasting asks if you want to convert to plain text
    • Totally new code plugin with syntax highlighting as you type
    • Option to make enter behave as a new line rather than with spacing
    • Editor is responsive, and ability to have small editor show in areas with less space
    • Member @mentions in posts can now be selected by tab key
  • Upgrade process
    • New upgrade process where new files are downloaded and installed automatically when possible.
    • Option to set email address for notifications when an upgrade is available
    • Banner shown to admins on the front end when an upgrade is available. It can be dismissed except for security updates.
  • Design and interface enhancements
    • Improve typography for titles
    • Better contrast for user-entered text (posts/comments/etc)
    • Brighten background colors
    • Pre-select text in when share popup is opened
    • Make positive/negative colors consistent across all uses
    • Better hover highlighting of 'blended' links
    • Better styling of mentions in posts (both the username, and the menu to select a user)
    • Better contrast for ipsAreaBackground
    • Flatten the default photo image
    • Checkbox/radio buttons now use custom styling, giving themers more control of their style
    • Improve popular/selected post styles
    • Change popular post icon to heart for consistency with likes
    • Make date a permalink for sharing
    • Improve sidebar contrast and block styles
    • Remove tab bar 'stretch' option and use CSS approach
    • Improve attachments dialog
    • Add more IDs to the user bar template for hook use
    • Add X to close mobile nav menu
    • Upgrade FontAwesome to 4.4
    • Select messages for multiple deleting in messenger
    • Make leaving a conversation clearer
    • Improve warning panel in user profiles
    • Move content status icons (pinned, hidden etc.) to start of row
    • Improve cover photo so it automatically puts it into position mode after uploading
    • Android title bar inherits theme header color
    • Added date uploaded to Downloads version dropdown
  • Browser notifications for completed actions (such as large file uploads)
  • Option to prompt users to re-consent to Terms and Conditions and/or Privacy Policy when you change them in AdminCP
  • Search
    • The main search box defaults to the app you are currently browsing unless you are on home page where it searches all
    • New default interface
    • Results now highlight and skip to search term in preview
  • Retina emoticons
  • Ability to uncheck all when adding Moderators in AdminCP
  • Instant Notifications
    • Receive notifications via your Browser Notifications of new Personal Messages and anything in the notifications menu
    • Intelligent auto-polling that only polls when needed to reduce server traffic
    • Browser local storage used, to allow for cross-communication if you have multiple tabs open to further reduce resource use
  • We now require a minimum PHP version of 5.4 though we do suggest at least 5.6. Version 5.4 will be supported for a short period of time as it is also EOL.
To ting her jeg likte:
  • PREVIEW BEFORE PUBLISHING
  • Selective quoting
Håper preview faktisk er for poster og ikke noe annet...
Preview before posting gjelder dessverre ikke innlegg men et meny system i bakkant.
Har sendt inn ønske om preview knapp så får se hva som skjer. Forhåndsvisning av bilder osv direkte i innlegg før man poster skal fungere mye bedre så håper det gjør at behovet ikke er like stort.
Selective quoting er slik du har forstått det samt at editoren blir bedre på mange andre områder.
Da skal det meste være på plass. En noe jeg må oversette + litt finpuss som jeg tar i morgen :)
Ser ut som det er en bug med Google Chrome at ikoner i editor ikke er på riktig sted. For de som opplever det så blir problemet løst hvis man sletter temp internetfiler i nettleseren sin.
Ellers er Mine innlegg tilbake og en ny type aktivitets meny hvor man kan skreddersy selv hvordan man ønsker å ha det.
Skal se om jeg rekker å lage en liten guide i morgen på det.
Tilbakemeldinger postes i tilbakemeldingstråden.
Ser ut til at den "hurtigknappen" til "nye inlegg" har blitt borte :O
[] 17 Kia Soul EV, Grå.
Ja, men oppsettet på det var jo helt mørkt i forhold til sånn det var :)
Kan velge om man ønsker utvidet visning eller ikke på høyre siden.
Kan også tilpasse sine egne visninger på hva man ønsker man skal se og velge hva man vil ha som standard der. Feks om man vil ha innlegg man har vært aktiv i.
Er det mulig å få tilbake den vanlige visningen av alle uleste innlegg og ikke denne rotete "aktivitetsstrømmen"? Jeg finner ingenting i innstillingene som heter "Deaktiver alle nye og uvesentlige funksjoner jeg ikke trenger eller vil ha, og la alt se ut som det gjorde før sånn at det er mulig å orientere seg"...
Det er for dumt at Tapatalk skal være den eneste måten å effektivt navigere forumet på når Tapatalk har vært en kriseløsning for å få sjekket nye poster på farten...
Jeg vet at jeg fremstår som en gammel, surmaget, gretten gnu som ikke vil ha forandring, og det får så være, men jeg fastholder at endring for endringens del ikke er en forbedring, særlig når det gjør navigasjon og oversikt mindre intuitivt enn før.
Er utviklerne av IP.Board lei av at folk bruker forumprogramvaren deres siden de aktivt går inn for å ødelegge systemet sitt?
mstrandbo
Jeg veit du sa vi skulle gi det litt tid, men er enig med Christer rundt uleste innlegg. Den forrige var jo veldig fin. Nå var det mer uoversiktlig.
Men prøver videre, også med den nye linken du la ut.
x2!
Var mye enklere å navigere rundt før, og alt var mer organisert.
Nå fremstår det egentlig som rotete, og aktivitetsstrømmen gjør meg gal!
"Nye emner" er vel en fin erstatter for den biten.
Men jeg har tro på at dette blir bra, for jeg skjønner at slikt tar tid. Håper bare det blir som Christer sier, at det blir litt som før, men med et mer moderne utseende ;)
Endret av robinrl
Nanolex Approved Detailer
OCDetail på Facebook
2010 BMW 116d M-Sport
Er ikke alltid lett å gjøre alle fornøyd. IPB fikk mye tilbakemeldinger på at det ikke var lett å holde oversikt over alle innlegg, kommentarer, bilder osv på det som var før. De kom derfor med 4.1 oppdateringen som endret på dette igjen for å prøve å ha et sted hvor man kan holde oversikt på hva som skjer på forumet.
Selv bruker jeg noen andre forum som hadde den og likte den godt, men forstår at ikke alle synes det. Er også vanskelig å henge igjen på 4.0 når det er flere feil som feks med editor som ble fikset i den versjonen.
Har mulighet til å tilpasse en del på det som er så kom gjerne med tilbakemeldinger på hva som kan forbedres. Så skal jeg prøve å endre det som jeg kan eller ta tilbakemeldingene videre til IPB.
Man kan også selv poste tilbakemeldinger til IPB her:
https://community.invisionpower.com/forum/481-product-feedback/
Jeg er av typen som ikke liker endringer (if it ain't broke, don't fix it) men skal nok få dette til, bare jeg får tilbake forhåndsvisning av bilder. Min siste utvei, blir å lage mine S&S på FB siden min i stede for her på DCN, noe jeg helst vil unngå.
Man får opp bildet når man legger inn en og en link og trykker enter eller space etterpå. Forstår at det er enklere for mange å poste inn linkene til alle bildene samtidig.
Dette har førsteprioritet så driver å maser på de IPB folka, samt sjekker opp mulighet for å legge til den funksjonen selv som en mod hvis de ikke ønsker å gjøre den endringen.
:thumbup:
  • Dennis unfeatured this emne
