PH/Blankbil
Nye Dodo Juice produkter
38 innlegg i emnet
These got launched to resellers and detailers on Friday, but will start to become available for general purchase this week:
SUPERNATURAL pH-NEUTRAL WHEEL CLEANER - 500ml
This is an ultra-safe pH-neutral wheel cleaner based on neutralised acid salt and surfactant technologies. It is properly pH-neutral - we found a few people were mistaking 'acid free' cleaners for pH-neutral products when actually many were brutally caustic. ('Acid free' sounds safe, but could refer to a very alkaline product). Whilst Mellow Yellow will always clean more effectively, this is a good choice for sealed wheels, or those with very sensitive finishes (anodised etc).
SUPERNATURAL ULTRA-FINE METAL POLISH - 100ml
An addition to our metal polishing range... this uses even finer media than our Fine polish, for a mirror like shine, either at the final stages of metal polishing or when polishing sensitive or soft finishes.
SUPERNATURAL MEDIUM CUT METAL POLISH - 100ml
Heavier cut than our Fine polish (but still relatively mild... it's not a grinding paste) this has a bit more effect and is a good workhorse in the metal polishing range. Allows you to start with this, then finish down through fine and ultra-fine polishes for a flawless (and very shiny) finish...
SUPERNATURAL METAL POLISHING KIT - 3x100ml = 300ml
All three metal polishes in a kit, with a microsuede polishing cloth.
SUPERNATURAL SATIN TRIM SEALANT KIT - 50ml
This is a slightly-less shiny (more 'natural') version of our gloss trim sealant. Still tricky to prep and apply, but the results can be just as impressive... Note, however, that we are working on a much easier-applying trim sealant for the main Dodo Juice range, although this will be based on more traditional technology and won't have the durability of a crystal resin product.
SUPERNATURAL MICROSUEDE BUFFING CLOTHS (TWIN PACK)
These very soft (CD-test compliant!) ultra-short pile buffing cloths are made from microsuede and are nice and absorbent - we found they excelled at final buffing (after the initial buff). Being short pile they remove excess oils and residue that longer pile microfibres may miss, helping prevent holograms. We recommend their use after oilier polishes, glazes, waxes and sealants at the secondary, or final, buff stage. We would use a deeper pile microfibre at the initial buff as the longer pile gets less saturated with residue. So if you were using Supernatural wax, the first buff would be with SN super-plush buffing cloth (long pile) and then the seconday buff would be with one of these. You get two for 6.50 GBP so they are decent value, and they are lint-free and edgeless.
DODO JUICE 'COVERED UP' DETAILING BAG
Basically, a Tooled Up bag (proving very popular) but with a removable cover on to keep dust out etc. Can be carried with cover on, or cover off. Also comes with a shoulder strap (detachable).
1
Dette blir nok spennende :)
Gleder meg sjukt til dette kommer:
DODO JUICE TARMALADE - tar, rubber and glue remover 200ml 195,-
Based on pure, natural orange oil, this paste clings to tar spots/rubber/glue without running off and trying to strip LSPs elsewhere on the bodywork. It smells great compared to normal solvent based tar removers and because you can dab on a small amount where it's needed, it's very economical to use. Almost too good to be a car care product - with the smell and texture it has, it almost deserves to be spread on toast.
DODO JUICE CLEARLY MENTHOL - glass cleaning spray - 500ml 115,-
A minty, alcohol-style glass spray, that works a treat when it comes to getting windows clean and smear-free (tackles bug splats nicely, for example). We may even be bringing out a concentrate to self-dilute, but this is trickier due to water hardness in some areas leaving residue. So what you see here, for now, is our ready to go offering, and the best thing is it can be used as a residue-free prep for our Supernatural Glass Sealant or as a maintenance cleaner OVER the glass sealant. And this is why glass products took so long - we had to develop all together so they could be compatible with each other.
SUPERNATURAL GLASS SEALANT KIT - covalent glass sealant - 50ml kit 250,-
Based on the latest covalent 'nano' technology, where atomic bonds are swapped between the sealant and the glass itself, to give outstanding durability (6-12months). Needs careful application (ie ultra-clean and residue/product free glass surface) but fantastic results. The little bottle comes with a lint-free applicator cloth and you'll easily do a set of windows with just 50ml - probably two or three sets in all likelihood. Can be maintained with our Clearly Menthol glass spray, once it has fully set-up.
DODO JUICE BASICS OF BLING WAX-SAFE WASH - 500ml 115,-
To bring Dodo Juice to a wider audience, we have simplified a few products and reduced the pricing - whilst keeping quality just as high as ever. This shampoo is the one we sampled a while back and many who tried it thought it was a new shampoo aimed at Supernatural or Born to be Mild... actually, it was our 'entry-level' Basics maintenance shampoo... pH-neutral, full of biodegradable surfactants, and still twice the industry-average dilution at 400:1 with water. Think of it as an 'RS' version of Sour Power... we have stripped the carnauba out as being an unnecessary ingredient, and made a purer and simpler shampoo as a result. As the name suggests, it is wax/sealant friendly and it can be used on windscreens without smearing etc.
Endret av PH/Blankbil
Kommer til å legge ut litt nytt fra Dodo Juice i helgen; Basics of Bling Clay Bar 55g, Basics Of Bling Clay Lube, Dodo Juice Nøkkelring, Tyromania Tyre Wax!
B)
En annen ting fra Dodo Juice flere sikkert kunne tenkt seg, er bøtte stickers :)
Wash:
Rinse:
Wheels:
-n
Wash:
Rinse:
Wheels:
-n
Skal ta med dette på neste ordre faktisk :)
Hehe, skulle ha venta til 180ml av Tyromania kom ja :) Men skitt au
Den basics of bling så interessant ut - fått testet den selv?
edit: og kommer den evt i 1l / gallon refill?
Endret av Essiek
Hakka 7 dekk på Blankbil? Og til en ganske god pris og? Kanskje jeg ender opp med noen dekk der? :)
Ja litt dumt det da, men regner med du blir fornøyd og kjøper den neste gang. Liker den mer og mer :D
Nei ikke testa enda, fikk den på onsdagen og har bare rukket og lukte på den, noe som var en deilig opplevelse bare det.. :)
Tror ikke den kommer i refill, men det skal jeg sjekke opp om :)
Ja tror ikke prisene skal være så aller verst. Men send meg en mail i tilfelle, så har jeg alt på mailkontoen om det blir noe :)
Har også fyllt opp med Basics of bling såpe, Spin Doctor, Lime Prime, bakplater +++
Kommer det piggfrie dekk også?
Ja skal fortsette å legge ut i ettermiddag.. :)
Må utvide lageret fælt nå da, dekk er jo ikke akkurat småtterier! :)
Ja vi får se, uansett så får jeg dekk og felg oppover to ganger i uka så det er ikke langt unna :)
(driver også å legger ut vinterdekk for dem som er interessert i det...ikke dodo dekk da, men Nokian bla.)
Piggfrie vinterdekk er jo av interesse da konebilen trenger nye vintersko...
Send meg en mail a, med dim: post@blankbil.no
Ja tror det ganske sikkert, kommer nok med nye buff daddy forsyninger om noen uker. Men da får en testa denne litt først :)
Start en konto
