PH/Blankbil
Ny Dodo Wax...
110 innlegg i emnet
Today, we launch a very special wax. SKULL CANDY. They should be with a few UK resellers by the 31st 8)
SKULL CANDY is a limited edition wax (666 units) available in 30ml panel pots (generally enough to do 3-4 whole cars).
It is a durable ‘hybrid’ wax/sealant recipe based on Hard Candy, similar to the Pro series waxes we already make. It has already found its way into the clutches of a top detailer, who felt it was one of the best waxes we have made. But let’s not pretend this is about the recipe. SKULL CANDY is an opportunity to own a limited edition Dodo Juice wax for a reasonable cost, and each panel pot is individually numbered.
There is a further twist to this launch.
Purchasers of this wax will also compete to win a SKULL CANDY MASTER CRANIUM. This is a wax unlike anything ever seen before – a scaled-down replica of a human skull containing a SKULL CANDY ‘brain’ personally handcrafted by pj and the chemists at Dodo Juice. This Master Cranium is NOT AVAILABLE FOR RESALE.
The only way to own it is to buy a SKULL CANDY panel pot and then:
1) Use skill and judgment to guess the weight (in grammes) of the Skull Candy Master Cranium BRAIN (not the whole skull, just the wax brain)
2) Write this number down on a piece of paper and then photograph it, with your SKULL CANDY base label in view, showing the unique SKULL CANDY limited edition number (1 to 666) that you have purchased
3) Send this photograph to skullcandy at dodojuice dot com before 30th November 2010.
The purchaser who has guessed closest when the competition ends, will win a Master Cranium. Only correctly completed email entries will be accepted (weight written down, Skull Candy base label and limited edition number in view and readable). Terms and conditions will apply.
Endret av PH/Blankbil
Spennende :)
Prøvde meg på et triks ved å se på detailingworld, men like hemmelighetsfulle der. Ja bortsett fra bildet da, men det sa meg ingenting (gir sikkert mening når infoen kommer)..
Hvis den heter "Daftalicious" så skal jeg ha royalties :)
Spennende :)
Ja det kommer nok info der i løpet av dagen, jeg kan ikke komme med bilder osv enda, for Dom eller PJ skal annonsere denne først!
Hehe, ja du får vente i spenning.. :P
Les første post!
Prisen på en slik panel pot er 160,-
Bestiller opp i dag, så dere kan godt lage dere en liste nedover her så er dere sikret denne. Er ett begrenset antall å få kjøpt siden dette skal deles på alle dodo juice forhandlerene så jeg får ikke all verden av Skull Candy.
1.
2.
3.
Osv..
Da får alle på listen denne først, og skulle det bli igjen noen, legges den i nettbutikken etterpå.
Les første post!
1.
2.
3.
Osv..
1. MortenB
1. MortenB
2. Bernhard
1. MortenB
2. Bernhard
3. kenset
1. MortenB
2. Bernhard
3. kenset
4. Ælen
1. MortenB
2. Bernhard
3. kenset
4. Ælen
5. Johnsta
Endret av johnsta
1. MortenB
2. Bernhard
3. kenset
4. Ælen
5. Johnsta
6. Andersh
1. MortenB
2. Bernhard
3. kenset
4. Ælen
5. Johnsta
6. Andersh
7. Mikael
1. MortenB
2. Bernhard
3. kenset
4. Ælen
5. Johnsta
6. Andersh
7. Mikael
8. Sandmo
Endret av Sandmo
1. MortenB
2. Bernhard
3. kenset
4. Ælen
5. Johnsta
6. Andersh
7. Mikael
8. Sandmo
9. mr.Sindre
1. MortenB
2. Bernhard
3. kenset
4. Ælen
5. Johnsta
6. Andersh
7. Mikael
8. Sandmo
9. mr.Sindre
10. Essiek
1. MortenB
2. Bernhard
3. kenset
4. Ælen
5. Johnsta
6. Andersh 7. Mikael
8. Sandmo
9. mr.Sindre
10. Essiek
11. Torby
1. MortenB
2. Bernhard
3. kenset
4. Ælen
5. Johnsta
8. Sandmo
9. mr.Sindre
10. Essiek
11. Torby
12. Paddo
1. MortenB
2. Bernhard
3. kenset
4. Ælen
5. Johnsta
8. Sandmo
9. mr.Sindre
10. Essiek
11. Torby
12. Paddo
13.kjimmern
1. MortenB
2. Bernhard
3. kenset
4. Ælen
5. Johnsta
8. Sandmo
9. mr.Sindre
10. Essiek
11. Torby
12. Paddo
13.kjimmern
14. Erik-w
