adnangri
GRUPPEKJØP Digital Paint Coating Thickness Meter Gauge
adnangri    2
adnangri
Jeg har tatt kontakt med en selger som har gitt meg et tilbud på gruppekjøp av
Digital Paint Coating Thickness Meter Gauge F/NF 1250μm
Brief Description :
This advance coating thickness meter (CM-8825FN) has 2 built-in probes (NF and F types) which is specially for measuring non-magnetic coatings. The F Probe can be used for measuring non-magnetic coating on magnetic substrate. And the NF Probe can be used for non-magnetic coating on non-magnetic substrate. It can automatically switch between NF and F mode. You can measure ultra wide range of coating from 0 - 1250 μm (0 - 50 mil). Additionally, you can also choose to measure by single or continuous mode.
Features :
  • Meets the standard of both ISO2178 and ISO-2360 as well as DIN, ASTM and BS. Suitable for the laboratory and for use in harsh field conditions
  • F Probe can be used for measuring non-magnetic coating on magnetic substrate.
    Examples of Non-magnetic Coating: Paint, Plastic, Copper, Copper Tile, Zinc, Aluminum Chrome, Aluminum Tile, Alloy Tile, Galvanizing layer, Phosphide layer and Porcelain enamel layer.
    Examples of Magnetic Substrate: Iron, Nickel and Magnetic metals
  • NF Probe can be used for non-magnetic coating on non-magnetic substrate.
    Examples of Non-magnetic Coating: Anodizing material, varnish, Paint, Enamel, Plastic coatings and Powder.
    Examples of Magnetic Substrate: Aluminum, Brass, Non-magnetic Stainless steel and Non-magnetic Metals
Dette er samme typen som jeg vet Ole Gunnar har handlet.
Prisene er som følger :
5 stk : 1385,- pr stk ink frakt til Norge
10 stk : 1325,- pr stk ink frakt til Norge
15 stk : 1265,- pr stk ink frakt til Norge
Da kommer norsk moms på 25% i tilegg.
Jeg vil bare lufte dette forslaget på forumet, om det ikke blir flere så bestiller jeg bare for meg selv. Men tenkte kanskje det er litt og spare hvis vi blir noen flere. Om noe er intereserte er det bare og skrike ut..
Bestiller alle for seg selv er prisen 1463,- pr stk.
One set included :
General Lee    25
General Lee
Frister, men får utsettes til økonomien bedrer seg. Ligger forresten til rundt 200 USD på eBay...
Hirobofly    49
Hirobofly
Fin den derre Paint Thickness Gauge saken. -Har den selv, superfornøyd!
- Her er litt hva jeg skribla om den da jeg kjøpte min: http://www.detailersclub.no/forum/topic/4062-lakktykkelses-maaler-impulskjoep/page__hl__Impulskj%C3%B8p
Også denne typen som ble testa imot PaintDetective-saken på test-panseret på kurset i Ås for noen uker siden. B)
adnangri    2
adnangri
Da er det 2 stk til nå. Har ikke sett denne typen til under 222,- + frakt. Men hvis den finnes til 200 så er det bare og å poste link General Lee
1. adnangri
2. Ståle
Fristen har jeg ikke satt noe dato på. Tenker meg at jeg bestiller første uken i januar.
jkart    398
jkart
Hvordan fungerer engentlig dette her.
Får du alle hjem til deg for å så sende de videre til de som er med på grupppekjøpet. I så fall vil enn vel ende opp med ca samme totalpris? :unsure:
@Generalen: USD 222.50
adnangri    2
adnangri
Vi må bli enige om hvordan vi gjør dette. Dette er noe vi må ta når vi blir enige om hvor mange det blir. Hvordan vi gjør med frakt videre fra meg er også noe vi kan bli enige om. De som bor i Oslo / Drammen omeråde kan også hente disse selv.
