Grefstad
Chemcial guys V4 all in 1 polish
Grefstad
Hei.
er det noen som har erfaringer med Chemcial guys V4 all in 1 polish?
Har en bil stående som jeg skal polere med denne i morgen, skal den buffes av etter hvert panel? skal den stå på og tørke til man har polert hele bilen?
Vet noen noe om holdbarhet  på denne?
Setter pris på alle svar.
Edited by Grefstad
Michael
Fra http://www.chemicalguys.com/V4_All_In_One_Polish_Shine_Sealant_16_oz_p/gap_106_16.htm. Ser ut til du enkel bare buffer bort rester rett etter polering av hvert enkelt panel/område :)
How To Use:
Hand Application:
Work on cool surface. Shake Well. Always work 2’ x 2’ section at a time. Using a polishing pad, work the V4 All-In-One Polish into the paintwork to remove swirls, scratches, and oxidation. Remove excess residue using a premium microfiber towel to achieve a brilliant shine. Follow by applying a coat of your favorite Chemical Guys wax or sealant.
DA Application:
Apply 4-5 drops to desired pad. Prime pad with Chemical Guys Pad Conditioner. Spread on speed setting 1. Set DA machine to speed setting 5-6. Always work 2’ x 2’ section at a time. Using moderate pressure, work area in 2-3 passes until polish becomes clear. Follow with light pressure to finish. Remove residue with a clean microfiber towel. Follow by applying a coat of your favorite Chemical Guys wax or sealant. For even more durable and long term protection, follow by applying a coat of your favorite Chemical Guys wax or sealant.
Rotary Application:
Apply 4-5 drops to desired pad. Prime pad with Chemical Guys Pad Conditioner. Set machine 1000-1500 RPMs to spread product. Always work 2’ x 2’ section at a time. Using just the weight of the machine (no pressure) work area in 3-4 passes until polish becomes clear. For final pass adjust speed setting to between 1200-1800 RPMs. Work until optical clarity has been achieved. Remove residue with a clean microfiber towel. Follow by applying a coat of your favorite Chemical Guys wax or sealant. For even more durable and long term protection, follow by applying a coat of your favorite Chemical Guys wax or sealant.
  • DCN Point 1
Grefstad
Ble anbefalt av Scandicshine å la den ligge 5-10 min, funker veldig bra! Fjernet faktisk mye riper, spent på holdbarhet da. Hehe
