Nanolex
Nanolex news 2015!
100 innlegg i emnet
Litt av hvert som dukker opp på nyåret.
Vi planlegger også ny nettbutikk samt noen utsalgssteder...
Samples går ut til NAD først. Har også reservert en del til resten av dere... :)
Info fra Tyskland:
Nanolex Pure Shampoo is a highly effective, yet extremely mild (pH-neutral), phosphate and NTA-free exterior car shampoo. The expert combination of surfactants guarantees highly effective cleaning, and detergent properties which give high foaming and superb slip properties.
Nanolex Pure Shampoo was developed, tested and produced in Germany.
Nanolex Pre-Cleaner Concentrate is a very effective, high-foaming, alkaline pre-cleaner. The carefully balanced mixture of surfactants, builders and solvents loosen up the grime and remove the more stubborn dirt such as insects, oils, grease and soot.
Nanolex Pre-Cleaner is also highly suitable for removal of wax, polish residue and silicones from the car’s exterior to prepare it for an application of Nanolex Paint & Alloy Sealants. The corrosion inhibitors in the formulation ensure good material compatibility with sensitive materials, such as anodized aluminium.
Dilution: 1:30 -1:10
Nanolex Pre-Cleaner Concentrate was developed, tested and produced in Germany.
Nanolex Microfiber Wash is specifically designed for microfiber towels and other accessories. High quality microfiber tools such as polishing pads, drying towels, wash mitts and applicator pads must be properly washed in order to protect their microfiber structure and functionality.
The special formulation - which is free from artificial fragrances and brighteners - ensures a rigorous, residue-free, yet mild and damage-free wash. This results in longer-lasting microfiber tools with intact capillary structures and unconfined dirt removal capability, not affected by detergent residuals.
Amphoteric surfactants with outstanding cleaning properties prevent streaking and smearing when the microfiber tools are used, while waxes, polymers and polishing residuals are completely removed. This specially-designed detergent is also highly suitable for an optimal, residue-free cleaning of polishing pads.
Nanolex Interior Cleaner is designed to gently clean all interior surfaces, such as leather, vinyl and plastic. Mild, low-foaming surfactants with outstanding wetting properties and detergent power remove dirt, oil, grease and nicotine easily and effectively. After using Nanolex Interior Cleaner, surfaces appear clean, fresh, streak free and without glossiness.
Nanolex Interior Cleaner is phosphate-free, non-acidic and non-caustic, and was developed, tested and produced in Germany.
Nanolex Nano One is a water-based sealant that simultaneously cleanses, rejuvenates and protects automotive paint. Developed and manufactured in Germany, Nanolex Nano One is a creamy, viscous composition based on nano-scale abrasives and wax. Nano One refreshes weathered paint finishes and removes micro scratches - in addition to this, an ultra-thin, surface-bonding wax-hybrid coating is simultaneously applied to the treated surface. All this is provided in a simple one-step application.
As a result, treated surfaces are much more reflective and exceptionally hydrophobic, therefore easier to clean. Washing is much less demanding, less time consuming and the overall effort to maintain a flawless finish is heavily reduced by using Nanolex Nano One.
The sophisticated chemical composition of Nano One provides a much better durability compared with pure organic waxes.
Nanolex Nano One was developed, tested and produced in Germany.
During the last few weeks we changed the material our labels are printed on to a high quality, pearlescent white foil which is more scratch resistant (almost 9h!) and in general better looking.
More updates for 2015
Ø NEW PRODUCTS / UPDATES (Planned release date: 4th week of January)
Trim (update: the chemical solution will be much less aggressive, yet work the same way as the existing) –
Tire & Rubber Restore (NEW)
Final One Quick / Matte Final One Detailer replacing Final Finish (NEW: improved slickness, improved gloss, improved beading); until this product is introduced the current final finish with the current price is available In limited numbers.
Glass Cleaner (NEW)
And finally a “glass coating” type product that is yet to be named. We are almost done with the development and hope we can introduce this product very early 2015.
The main characteristics are a highly improved depth of the paint...
As well as improved scratch resistance on softer paints (tests will be performed and results of course shared).
Of course the product will have an outstanding beading effect as well...
This product will overall have different characteristics than our existing products, for example the application will be more difficult than for example that of Professional / Ultra Paint & Alloy Sealant, also the chemical resistance against solutions with a pH >11.5 will be less than Professional Paint & Alloy Sealant.
We are producing the product ourselves and are hence in a position to offer it at a very reasonable price.
If everything goes well this week we might be able to send out first samples in 2-3 weeks.
This product will most likely also be suitable for plastics!
Ø CHANGES IN SIZES:
- Reactivating Shampoo 250ml will be discontinued
- Paint Cleaner/Glass Cleaner (new name: Nanolex EX)100ml will be discontinued
- Trim Revunator 50ml will be discontinued (new 100ml will be less expensive)
Ø NAME CHANGES:
Nanolex Premium Spray Sealant -> Nanolex Spray Sealant
Nanolex NanoWax -> Nanolex Nano One
Nanolex Premium Textile Sealant for Convertible Tops –> Nanolex Convertible Top Sealant
Nanolex Premium Textile Sealant -> Nanolex Textile Sealant
Nanolex Premium Paint/Glass Cleaner -> Nanolex EX
Nanolex Matte Pro Paint Sealant – Nanolex Ultra Matte Surface Sealant
Nanolex Matte Paint Sealant – Nanolex Matte Spray Sealant
Nanolex Matte Final Finish – Nanolex Matte Final One
Nanolex Matte Shampoo – Nanolex Reactivating Matte Shampoo
Ø PACKAGING:
We are almost out of the packaging we’ve been using for almost 2 years.
The new packaging will be very sturdy, also the boxes will allow the products to stand upright.
Endret av Nanolex
1
Spennende!
Interessant. :)
Må prøves :thumbs:
Det var et spennende nytt utvalg produkter, og om dette holder samme standard som de øvrige produktene fra Nanolex er det bare å glede seg. Det gjør i alle fall jeg. Glass Coatingen har jeg store forhåpninger til :fun:
Hvis glasscoatingen er like bra som eller bedre enn Glass Ultra, så skal jeg ha en flaske og smøre godstoffet på samtlige ruter jeg kommer over.
Snasent! ser veldig bra ut der dere har drevet på med. Ser veldig delikat og skikkelig ut den innpakningen, spot on:)
Dere har veldig gode produkter, så blir morro å prøve litt nytt når den tid kommer!
Den voksboostern som blandes 1:200 i skumkanon blir ikke fornyet? Vil ha mere enn den ;) Feil med skumkanon min så det ble ikke 1:1000 en gang.. Men beader godt lakken fordi :)
Jeg tror at glass coatingen som det er snakk om her er en LSP for lakk, ikke glass.
Er det wash coat du tenker på?
Mange spennende nyheter og oppgraderinger på kvalitetsprodukter. Ser frem til å prøve i 2015. :)
Spot on Øyvind...
Spennende dette ja.. moro at det kommer litt nyheter :)
Ja wash coat hette den vel :) bruker på vinterbilen min.
Genialt produkt. Kjøpte akkurat en 500 ml flaske da 250 ml flasken min snart er tom.
Spennende :)
Knall! :)
Dette gleder jeg meg til Håvard :D
Sjå her ja :) må vel teste noe av dette i 2015 ja :)
