Nanolex
Nyheter fra Nanolex Tyskland...
Limer inn info fra Nanolex Tyskland.
Har kuttet ut en del som kun er ment for meg... ;)
As announced earlier this year quite a few things have been going on and were finally ready to announce a few things officially.
SHAMPOO UPDATE
Due to REACH setting in at the end of the year we have had to change a few products. In most cases you wont notice, but in case of the shampoo we had to switch to a slightly different scent and a few changes to the ingredients were also done.
We have put in a lot of effort to keep the shampoo as good as it always was, but actually it is even better now. Once you test it youll notice better foam as well as a slightly improved hydrophobic effect on the car.
WHEEL CLEANER
This has been a topic for some time now and Im sure youve already seen some sneak peak pictures on social Media.
We are now ready to roll out the Nanolex Wheel Cleaner & Iron Remover to the public.
Sticking to our credo to offer things that are somewhat revolutionary or at least superior to traditional car care products this wheel cleaner has a few interesting features, besides the actual cleaning power.
As youll be able to tell shortly the viscosity of the product is neither very liquid nor gel-like, but something inbetween, leaving it wet for a longer time and allowing it to flow into hard to reach areas at the same time.
Also a difference will be the very low smell (compared to other wheel cleaners with color indicator).
The official product info is:
Nanolex Wheel Cleaner & Iron remover is an effective and extremely fast acting wheel cleaner and iron contamination remover.
It is less aggressive than traditional acidic wheel cleaners, yet just as effective.
Its powerful formulation dissolves all iron contamination including harmful brake dust upon contact.
An innovative colour change mechanism from clear to red indicates when the iron particles have been neutralised and can be safely rinsed away.
Nanolex Wheel Cleaner & Iron remover reduces the need to agitate treated surfaces due to its unique viscous formulation and superior dwell time.
Developed, tested and produced in Germany
With the following details on how to use:
1. Spray Nanolex Wheel Cleaner onto the surface to be treated
2. Allow to dwell for 2 3 minutes until the colour changes to red
3. Agitate with a soft wheel brush if required
4. Do not allow to dry
5. Rinse with clean fresh water
For the first time in our history we have decided to use a bottle different to the neutral ones we use for the rest of the line.
Nanolex Wheel Cleaner & Iron Remover will be ready to ship next Wednesday, the 11th of June.
NEW SIZES
Responding to numerous requests over the last few months we have decided to offer most of the products in larger sizes at a considerable rebate.
NEW MERCHANDISE
Again responding to our customers demand we have decided to officially offer merchandise products from Nanolex from now on.
VI SATESER PÅ EGEN APC OG NY TYPE LAKKFORSEGLING I LØPET AV 2014
Håvard
Nice! Gode nyheter:)
Blir spennende å se når det kommer..
Kan bli spennende dette.
Detta har jeg gleda meg til :)
Venter på sample på lakkforsegling jeg da :P :P :P
Kommer etter sommerferien...
Vet dere om klistremerker er langt unna ? :)
Har en bil jeg gjerne skulle ha satt "nanolex behandlet" på :)
"Nanolex-behandlet" eller "Nanolexbehandlet", isåfall...
1
Skal komme med neste sending...
Håvard
