Johnny-Puma
Ingen ende på innkjøp: Aldri møkkete bil ☺
Johnny-Puma    72
Johnny-Puma
Da er mange innkjøp gjort:
Rupes:
1 stk Rupes Bigfoot LHR 15ES Oscillerende:
4 stk Rupes Hvit Ultrafine Finishing Pad 150mm
4 stk Rupes Gul Fine Polishing Pad 150mm
4 stk Rupes Grønn Medium Polishing Pad 150mm
2 stk Rupes Blå Hard Polishing Pad 150mm
1 stk LHR 12/15ES Bakplate
2 stk Rupes Microfiberpad Gul 150mm
2 stk Rupes Microfiberpad Blå 150mm
1 stk Rupes BigFoot LHR 75E Mini:
2 stk Rupes Gul Fine Polishing Pad 100mm
2 stk Rupes Blå Hard Polishing Pad 100mm
2 stk Rupes Microfiberpad Gul 100mm
2 stk Rupes Microfiberpad Blå 100mm
1 stk Rupes Diamond Gloss – Ultrafin 1000ml
1 stk Rupes Keramik Gloss – Fin 1000ml
1 stk Rupes Quarz Gloss Gel – Medium 1000ml
1 stk Rupes Zephir Gel Compound - Grov 1000ml
Swissvax:
1 stk Swissvax Master Collection:
  • Cleaner Fluid (lakkrens/prevoks olje) 250 ml
  • Cleaner Fluid Medium (rubbing/ripefjerner) 250 ml
  • Cleaner fluid Strong(Rubbing/ripefjerne) 250 ml
  • Paint Rubber (clay/lakkrubbing)
  • Quick Finish (glansfornyer)
  • Car Bath (bilsjampokonsentrat) 250 ml
  • Wheel (felgrenskonsentrat) 250 ml
  • Mixing Bottle (sprayflaske) 250ml
  • Swissvax MicroWash mikrofiber klut (gul)
  • Protecton (plastfornyer) 250 ml
  • Leather Cleaner (skinnrens) 250 ml
  • Leather Milk (skinnmelk) 250 ml
  • Leather Cleaning børste
  • Metal Polish (krom, alu, etc.) 50 ml
  • Woodpolish (voks for lakkert tre)
  • Crystal (glassrens) 250 ml
  • 1 påføringspute for Cleaner Fluid
  • 1 Påføringspute Puck type Mini
  • Car duster Mini
  • Swissvax Micro-dry Tørkehåndkle
  • 2 Mikrofiberhåndklær Micro fluffy (for voks og Cleaner Fluid)
  • Microglass duo(vindusklut)
1 stk Swissvax Shield
2 stk Swissvax Autobahn
2 stk: Swissvax Pneu Svart Matt
1 stk: Elephant Leather Fat
2 stk Swissvax Detail Brush
2 stk Swissvax Wheel Brush.
1 stk Swissvax Lotos Protectant Kit – Impregneringssett
1 stk Swissvax Micro dry
6 stk Swissvax Waschpudel
4 stk Swissvax Micro duo glass klut
PolishAngel:
PolishAngel® Master Sealent 200ml
Chemical Guys:
1 stk Chemical Guys Grime Reaper 1 Gallon
1 stk Chemical Guys GLOSSWORKZ 1 Gallon
1 stk Chemical Guys Luber Claysmøring 1 Gallon
2 stk Chemical Guys Citrus Wash & Gloss 1 Gallon
1 stk Chemical Guys Maxi Suds 2 1 Gallon
1 stk Chemical Guys streak free glass rens 1 Gallon
1 stk Chemical Guys Bare Bones 1 Gallon
Nanolex:
3 stk Nanolex Glass ultra sett
10 stk Nanosvamper
Scholl:
1 stk Scholl Concepts RIM7 5 liter
1 stk Scholl Concepts Finish Kontroll Spray
1 stk Puck fra Scholl for voks/sealer
1 stk Våtslipe kit
Bilthamber:
1 stk Bilthamber Korrosol 5 liter
2 stk Bilthamber Surfex HD 5 liter
4 stk Rain-X
1 stk Rain-X Vinduspylertilsetning
1 stk P21S Power Gel felgrens 5 liter
1 stk Mac 124 Prickbort 10 liter
1 stk Auto Finesse Citrus Power - Grime Remover 5 liter
1 stk Owatrol Polytrol 0.5 L
Spray/doseringsflasker:
2 stk Kwazar Venus Super 360 Pro+ 1,5 liter
3 stk Kwazar Mercury 360 Pro + Double-Action Spray Bottle 0,5L
3 stk Kwazar Spray flaske 1.0
1 stk Zonaxx pumpeflaske 1,5 liter
15 stk Atomiza Chemical Spray Head med flaske på 650ml
Clay:
2 stk Clay towel 32 x 30 cm fine grade
1 stk Clay towel 32 x 30 cm medium grade
1 stk Bilt-Hamber AutoClay Soft
1 stk Auto Finesse Glide - Clay bar lube
2 stk 3M Maskeringstape 233+ 18mm
1 stk 3M Maskeringstape 233+ 36mm
Bøtter:
1 stk Grit guard Padwasher
5 stk Bøtter med Grit guard og lokk (gikk litt i surr)
2 stk Grit guard puter
2 stk Grit Guard Dolly
Vaskeredskap:
1 stk Wheel Woolies - Caliper Spoke Woolie
1 stk Wheel Woolies - 3 pakk (WW-3K)
1 stk Tekstilbørste
1 stk Vikan dekkbørste
1 stk Mothers Børstesett
1 stk Mothers Børste til hjulbuer
1 stk Mothers Felgbørste
1 stk EZ Detail Brush stor
1 stk EZ mini Felgbørste
2 stk Bilt-Hamber AutoMitt
10 stk BN svamper
Microfiber:
6 stk Miracle Dryer
2 stk Ronny's Fluff
5 stk 40 x 40 DETAIL MASTER PRO Ultra Plush Polish
2 stk120 x 65 DETAIL MASTER™ PRO Avalanche Ultra Plush Drying Towel
4 stk 40 x 40 DETAIL MASTER™ PRO Premium Glass and Window Towel
5 stk 40 x 40 DETAIL MASTER™ PRO Split Purple-nality (Dual Pile)
5 stk 40 x 40 DETAIL MASTER PRO The Miner: Premium Metal Polishing Towel
4 stk 40 x 60 DETAIL MASTER PRO Edgeless Super Plush Blå 500gsm
25 stk 40 X 40 Premium Blue DETAIL MASTER™ Microfiber Terry Towel
1 stk Micro-Restore Detergent Concentrate
Oppdaterer alt på denne siden hva jeg har kjøpt, for jeg er tross alt over 40 :blush:
Kom gjerne med tips på hva mer jeg "må" ha :rolleyes:
Endret av Johnny-Puma
MKLars1    141
MKLars1
P21S powergel er en helt super felgrens...!
Swissvax Autobahn er en helt super felgvoks...!
Swissvax Pneu burde "dekke" resten!
hø hø, the puns...
Finfin liste du har forresten! men du mangla felg/dekk så bare de tre tingene over som mangla! (som jeg kan se)
Johnny-Puma    72
Johnny-Puma
hø hø, the puns...
Takk for tilbakemelding, da settes det opp på neste bestilling ;)
ØHN    5 295
Lakkrens og voks hvis du ikke har. Det vil gi bilen du skal selge et løft, og gjøre den nye bilen lettere å vaske skånsomt. Mye bra du har handlet deg allerede. ;)
Breitling    71
Breitling
Du kan i allefall fjerne asfaltrester i hele nabolaget ;) Ser ikke at du har en felgrens? PS21S PG er suverent, selv er jeg mest fornøyd med Rim7 fra Scholl.
Hvilke sprayflasker planlegger du å bruke på Prickbort og Korrosol? Regner med at Kwazar-flaska skal brukes til Surfex?
Ift valg av voks er det en verden av morsomme muligheter ^_^
Johnny-Puma    72
Johnny-Puma
Takk for alle tips, glemte å skrive at det var 3 pakk med Kwazar-flasker :rolleyes:
Johnny-Puma    72
Johnny-Puma
Kwazar flaska kan få trøbbel med prickborten etterhvert:P
Har denne fra biltema til Prickbort. Fungerer fint. http://www.biltema.no/no/Fritid/Hage/Hageredskaper/Redskap/Trykksproyte-45578/
Har hatt prickbort på kwasar i 1,5 år må uten problem. Eneste er at slangen er blitt litt stiv, men funksjon er fremdeles tipp topp!
Jeg prøver :) De flaskene er ikke den største utgiften med denne hobbyen :rolleyes:
Godt ikke kona har profil her inne B)
tr86    526
tr86
Tell me about it..
Hun skjønner vel tegninga, men sikkert ikke helt hvor mye som faktisk har gått på dette :-P
hmsilset    3 830
Masse bra her! Du har nok havnet på detailerkjøret ;)
Johnny-Puma    72
Johnny-Puma
Da etter innspill fra forumet, er nå dette bestilt:
Nå får det holde for denne uken og forhåpentlig vis for de neste 5 årene :blush:
Breitling    71
Breitling
Master Collection med Shield er en heftig pakke :) Du kommer til å hekta, det er jeg sikker på!
Johnny-Puma    72
Johnny-Puma
Håper det, men ikke si noe til kona :D
Bernhard    2 323
3 år på min Kwazarflaske og holder fint enda :-)
Den gamle typen og ikke 360 jeg har..
truhaa    1 525
De Kwasarflaskene med vanlig slange i funker supert, 360 utg har en tendens til å bli stive med Prickbort
Ellers ser det ut som du har havna skikkelig på bilpleieskråplanet... blir rent og pent av sånt :)
Johnny-Puma    72
Johnny-Puma
Litt nytt bestilt den siste uken :D
1 stk Swissvax Master Cooler bag, må jo ha noen steder å legge alt utstyret som jeg sier til kona at jeg har "lånt" av en kompis :rolleyes:
2 stk Swissvax Waschpudel
1 stk Swissvax Dørbeskytter (par)
1 stk Swissvax Micro duo glass klut (2kluter)
1 stk Miracle Drying Towel
1 stk. RUPES Bigfoot LHR 15ES Oscillerende - Deluxe Kit, godt den kommer i bag :D
4 stk RUPES Ultrafine Finishing Pad 150mm
4 stk RUPES Fine Polishing Pad 150mm
2 stk RUPES Medium Polishing Pad 150mm
1 stk. RUPES Diamond Gloss – Ultrafin 1000ml
1 stk. RUPES Keramik Gloss – Fin 1000ml
1 stk. RUPES Quarz Gloss Gel – Medium 1000ml
2 stk. 3M Maskeringstape 233+ 18mm
1 stk. 3M Maskeringstape 233+ 36mm
1 stk. Wheel Woolies - Caliper Spoke Woolie
1 stk. Wheel Woolies - 3 pakk (WW-3K)
1 stk. Auto Finesse Glide - Clay bar lube
1 stk. Bilt-Hamber AutoClay Soft
1 stk. Micro-Restore Detergent Concentrate
1 stk. Tekstilbørste
2 stk. Bilt-Hamber AutoMitt
Har vært så mange ganger på posten den siste uken, at når jeg kommer inn står pakken klar på disken når dem ser meg :shocking2:
Johnny-Puma    72
Johnny-Puma
Re-hab neste :D
Ja blir vel Modum bad eller Blakstad på meg snart :wacko:
Haha :D
