Scandic Shine / Ketil
SS: Gruppekjøp Valet-Pro 5L kanner
Hei,
Da er det lenge siden vi har kjørt noe gruppekjøp for forumbrukerne :)
Så vi kjører i gang med et gruppekjøp på disse produktene:
Alle i 5L kanner.
Valet-pro Snow foam combo
Valet-pro Bilberry wheel cleaner
Valet-pro Citrus pre wash
Valet-pro Poseidon car wash
Gruppekjøps pris er 299 kr stk.
Ved kjøp av alle 4, får man en pakkepris på 999 kr :)
Påmelding/Betaling.
Vi kjører gruppekjøpet i 14 dager fra i dag, alle som er interessert setter seg opp på listen under. Vi tar bestillingen og betalingen igjennom nettbutikken, når gruppekjøpet er over.
Snow Foam Combo:
Preparation - We currently have two chemicals which we promote for Preparation. Snow Foam combo and Citrus PRE wash.
The criteria for preparation products is high
cleaning ability. A product that will deal with petrol, diesel and
grease stains. Removes bug splats and other grime contaminates with
ease. Snow foam combo does this well.
Snow foam combo is a high foaming TFR with
exceptional cleaning power. It's quick and easy to use. It's perfect for
preparing exceptionally dirty
cars ready for resale. Snow Foam combo is the first stage of the wash
process and will remove traffic film prior to washing. Making the wash
process quick and easy.
Citrus pre wash:
Pre wash is the first stage of Valeting. It makes
cleaning your car easier as it removes the bulk of the grime from the
paint surface as well as eliminating bug splats and general grime.
By using this product prior to the shampoo stage
you make sure you help keep the paint surface in good condition. This
stage is important in the Prepare stage but is vital in the maintain stage.
Bilberry wheel cleaner:
ValetPRO Bilberry Wheel Cleaner gets a fresh twist with a brand new
formula, making it even easier to use and more effective than ever.
Simply spray on and jet wash off. No scrubbing, no agitation – just
clean, hassle-free, sparkling wheels.
Poseidon Carnauba Wash
This is one of the finest car shampoos on the market.
Blended with Carnauba wax, this product will actually leave the
paintwork beading after a wash, even if your car has never seen even one
coat of wax before. It also adds a glossy-look to the paintwork too.
This gives true power in maintaining a car and
preserving a ‘new look’ by protecting the paintwork and other areas that
can't be reached normally. Our Poseidon Carnauba Wash shampoo also
helps protect your car from rust whilst maintaining waxes, sealants and
factory applied sealants through a regular washing routine.
Adding just 50ml of Poseidon Carnauba Wash to 5L of water means a great dilution rate and superb value for money!
1:
2:
3:
4:
Endret av Pirex/Scandicshine
Roy Inge
Savner litt info om bestilling etc her.
Er det frist for å melde seg på gruppekjøp?
Bestiller man i nettbutikk med ref til gruppekjøp, eller blir det sendt ut krav om betaling ved X antall påmeldte?
halldor84
1: Halldor84 - Alle fire 999, -
Endret av halldor84
Roy Inge
2: Roy Inge: 2 av hver :P kr1998,-
Endret av Roy Inge
Jensenjr
Er Citrus Pre-wash den samme som den gamle Orange Pre-Wash?
JørgenT
3: JørgenT: 1 x Poseidon Car Wash
JP_Ra©ingTeam
4: JP_Ra©ingTeam : 1 x Poseidon Car Wash + 1x Bilberry wheel cleaner
flyfizz
5: flyfizz: 1 x Valet-pro Bilberry wheel cleaner
Ja "nye versjonen" men er fortsatt samme.
Lamar
6: Lamar - Alle fire 999,-
vidar b
7: vidarb alle 4 999,-
Endret av vidar b
Johnchr
2: Roy Inge: 2 av hver kr1998,-
8: bullit87: alle 4 for 999,-
9: svrei: alle 4 for 999,-
S-Stian
10: S-Stian: 1x Bilberry + 1x Citrus Prewash
Christer R
11: Christer R: Alle 4 for 999,-
halldor84
Dobbler bestillingen min eg:)
1: Halldor84 - Alle firex2: 1998,-
RawKuz
Kaster meg på jeg også, veldig bra tiltak :)
12. RawKuz Alle 4 for 999,-
13. Knutis - Alle 4 for 999,- (Sendes sammen med "alt" annet)
