Scandic Shine / Ketil
Scandicshine.no Gruppekjøp Bilt-hamber Korrosol
Scandic Shine / Ketil    257
Bilt-Hamber har kommet med en helt ny fallout remover, altså avfettning som fjerner metallpartikler osv i lakken.
Tenkte vi skulle kjøre igang et gruppekjøp på denne, både 1L og 5L kanner.
PRIS PÅ 1L 129 kr
PRIS PÅ 5L 549 kr KJØPER MAN 2 STK BLIR DET 1000 kr!
Litt info om produktet:
Bilt Hamber Korrosol is a non-acid, non-alkaline fallout remover for the safe and effective removal of embedded metallic particles that contaminate the vast majority of road going vehicles. You may not have noticed by looking at your paintwork, but next time it's washed and clean lightly feel the paintwork, especially the horizontal panels; bonnet, boot lid, roof etc. Very gently with finger tip touch you'll be able to feel a rough grittiness. You may well think this is dust landed from the air - it's not. Airborne metallic particles liberated by braking surfaces, such as pads and discs fill the air along our roads, when hot after the car in front of you brakes your car travels through them, as a result they embed themselves in your paintwork.
Here they react with rainwater or air moisture and begin to corrode and as the corrosion product (rust) occupies four times the space of iron the paint is slowly ruptured around the embedded particle. This action destroys both the aesthetic and protective qualities of the finish.
While harsh acids such as phosphoric and oxalic acids maybe use with good effect to remove the contamination, these acids to not discriminate between corrosion and good steel not even paint films themselves, so while the particle is removed and base metals or coatings can also be attacked. Korrosol's effective formula is simply sprayed onto the contaminated panel a rapid and dramatic colour change takes place which indicates that the corroded part is water soluble after which a rinse with water leaves the panel free of metallic embedment. Korrosol is safe to use on all auto body paint finishes including lacquers.
Endret av Pirex/Scandicshine
Klykken    99
Klykken
Er tom for Iron-X, så hvorfor ikke.
1: Klykken - 1stk 5Liter
2:
Endret av Klykken
tharshan    52
tharshan
2: tharshan - 2 stk 1 Liter
Endret av tharshan
Ikke helt sikker enda, men ca 189 kr for 1L og 699 kr for 5L
Geir    335
Geir
OK. Var bare nysgjerrig på prisen ift Iron X. Leverer den like bra er det jo klart mer bang for the bucks :)
Har brukt den selv en god stund og fungerer meget bra :)
Klykken    99
Klykken
Regner med det. Btw, lukter denne bedre enn Iron-X sin påståtte "cherry"-lukt?
Endret av Klykken
Kristian Nafstad    39
Kristian Nafstad
3: kristian_ - 2stk 1 liter
4:
Endret av kristian_
Ineditus    170
Ineditus
4: Jac - 3stk 1L
5:
stigwh    0
stigwh
4: Jac - 3stk 1L
5: stigwh 1 stk 5 liter
bilmagikeren    40
bilmagikeren
Hvor lenge vil gruppekjøpet vare, og når sender dere ut varene:)?
Geir    335
Geir
Jeg kunne også tenkt meg å få ETA før jeg eventuelt hopper på her :)
Det er bestilt, vil ta ca 14 dager ved normal frakt tid:)
ustrucks    67
ustrucks
4: Jac - 3stk 1L
6: ustrucks 1 stk 5 liter
Jørgen    15
Jørgen
4: Jac - 3stk 1L
7: Jørgen 1 stk 5 liter
Henkem    2
Henkem
4: Jac - 3stk 1L
8: henkem 1 stk 5 liter
Bent    341
Bent
4: Jac - 3stk 1L
9: Bent 1stk 5 liter
Endret av Bent
